Problem 'using n95 as modem'
3 replies · 4,636 views · Started 12 September 2008
Hello ... I am getting problem connecting my mobile as modem to use my laptop
I have downloaded latest nokia pc suite and my n95 8gb has 20 v software. I have o2 connection [with free web bolt on]. I was trying to use my mobile as modem to run internet on my laptop. When i click 'connect to internet' on my pc suite it shows 'No modem found ..plz install nokia connectivity cable driver software'. When i cheked in 'control panel' it shows that i have already installed 'nokia connectivity driver' and 'nokia flashing driver'..
could u plz help me find out how to solve this problem?
thanks
Not sure what your problem is, when I connect my N95 (02) to the laptop (vista) it just seemed to work at the click of a button. One thing you need to know though is that the terms and conditions of the "web bolt on" may not allow you to use your phone as a modem for a PC
"Data Bolt On Terms
The Web Bolt On allows you unlimited use of Telef�nica O2 UK Limited's Edge/GPRS/ 3G networks (as applicable to your handset), for personal internet use via your mobile phone. All usage must be for your private, personal and non-commercial purposes. You may not use your SIM Card:
in, or connected to, any other device including modems;
to allow the continuous streaming of any audio / video content, enable Voice over Internet (Voip), P2P or file sharing; or
in such a way that adversely impacts the service to other O2 customers
If O2 reasonably suspects you are not acting in accordance with this policy O2 reserves the right to impose further charges, impose network protection controls which may reduce your speed of transmission, remove the Web Bolt On from your account or disconnect your tariff at any time, having attempted to contact you first. "
