E71: Max. number of calendar entries in Active Standby?
1 replies · 6,361 views · Started 15 September 2008
What's the maximun number of calendar entries that are shown in the "Today" (active standby?) screen of E71?
I currently have a HTC TytnII and I can see 6 entries without scrolling and I hope that the E71 can do the same. If not, is there a 3rd party app that will let me either make the font smaller or add more entries on the active standby screen? I really like the E71 opposed to the sluggish HTC but the ability to show multiple calendar entries is really important for me.
The next best thing on my HTC after the ability to actually use it as a phone, is that I can just take a quick look on the main Today screen and see exactly what is my agenda for the day.
Hiya
Lots of us WM users moving to the E71 it seems
As far as I can tell 4 is the most you can see, but that might depend on what other Active plugins you're using.
There are no 3rd party Active standby plugins, as far as I can tell.
Try turning off the pugins you don't need and make some dummy appts to test it.
I did read something about changing fonts just the other day, but I can't find it now. That might give you more space to play with.
This is the best I've found, but I've not tried it, so take care and do this at your own risk!
http://symbianworld.wordpress.com/2008/01/19/how-to-change-fonts-in-s60-3rd/
