HI!...
How you can put any text on the DATE area on desktop?
thanks!
cya!
HI!...
thanks!
cya!
If by date area you mean the area under your operators logo/name, then yes in any profile but general, just change the profiles name, and even make it match the general profile if you want, and then when you make it active the name of it will be displayed in that bar that goes under the clock/operators logo.
I hope that helps.
Change the profile name, and use that profile.
(Doesnt work on the default one as you cant rename it)
HI!!
Thanks all for the answer... 😃
BTW!.. nice trick! 😉
cya!
