Keep getting this message when I try to log onto certain websites with my phone(banking, email, etc)-only started happening recently. Has anyone any idea what could be causing this? Cheers...
"Unable to create a secure connection to this server"?
Have seen this problem a few times around the net with some intermittent fixes.
What network?
What firmware you on?
How are you connecting (GPRS/Wifi)
Is it only ssl secure sites?
Are you using Nokia browser for the web?
In order. T-mobile, v30, GPRS, SSL sites only, Nokia browser. Thanks.
ok,
2 thngs to try.
1. The easy one:
try going to TOOLS>SETTINGS>CONNECTION>ACCESS POINT and select the edit for the t-mob access point.
In there you probably have standard set as the authentication settting. Change it to secure and then try again... you may need to restart the phone competely tho... so take the battery out for a little while and then restart.
2.
Delete your settings and then get them sent again from T-mobile. You may need to back up your messages too and delte them incase you got any network messages.
Thanks. Incidentally, I can no longer get internet radio to work-keeps timing connection out. Could this be related?
SpookyElvis wrote:Thanks. Incidentally, I can no longer get internet radio to work-keeps timing connection out. Could this be related?
Ive just tried streaming internet radio thru my t-mob settings and theres no problems.
Check your streaming qualitites in the settings.
I always stream via wifi tho.. so I cant comment on how long it would have streamed without issues for me on t-mob internet.
