When I deleted a gif I was using for an animated background from the images folder it stopped animating, was this coincidence?
Also some gifs I have tried do not update their frames properly and leave trails behind, does this depend on the gif?
Thank you
I have a problem with eprofiles.
[quote="lakeywhite"]When I deleted a gif I was using for an animated background from the images folder it stopped animating, was this coincidence?[/quote]
It uses the gif, so you shouldnt delete it.
[quote="lakeywhite"]Also some gifs I have tried do not update their frames properly and leave trails behind, does this depend on the gif?[/quote]
that depends on the gif type.
Thanks for clarifying that.
I thought that by setting it as a background, like when eprofiles is not being used, that it would copy the gif to another directory and therefore I could delete the one in the image folder and save memory. If that is not the case then I will have to try to remember not to delete it.
