Problem with n95-2 SIP outgoing voice(bad outgoing voice quality)
3 replies · 5,614 views · Started 16 September 2008
Hi all. I use my n95-2 with my home wifi connection to receive sip incoming calls using n95 built in sip functionality. The problem is that when i receive the calls, the incoming voice quality is good but the other side tells me that my voice is like robot!! This is the case with all different sip providers that i tried !!However,if i use the same sip accounts with fring the quality of outgoing voice is good!! I am using Linksys N Ultra Range Plus ( Wireless-N Broadband router:WRT160N) with hidden SSID.I be happy if an expert tell me how i can fix this problem and be able to use sip with both outgoing and incoming good voice quality.Thank you and looking forward for replies.
Hi all . I try to receive orbtalk incoming call in my n95 but it never rings!! I am using n95 sip built in functionally.The n95 sip client registers successfully to orbtalk server but when i receive incoming calls my phone doesn't ring!! However, When i use the same orbtalk account with fring the phone rings for incoming call!! Could any one help fix this problem?Thanks
There are simple settings in the phone you have to configure to make it ring. By default the internet call ring tone is off, no matter what profile u are on. As well as other items.
tigerfox wrote:There are simple settings in the phone you have to configure to make it ring. By default the internet call ring tone is off, no matter what profile u are on. As well as other items.
Thank you for your reply. The default internet call ring tone is not off since the phone rings if i use other sip services such as gizmo ,voipcheap ...
