Feature pack2 on N78
0 replies · 2,244 views · Started 16 September 2008
Came across a few features while toying around with n78 and found them worth talkin bout.
Automtic recognition of text msg or Multimedia msg. The moment a pic or audio is inserted into a text msg, the message converts into a Multimedia one.
User posted image"]
[/URL]
Also discovered this option of timed profile, helps in overcoming a common prob. of forgeting to change d profile once the meeting is over. Simply define d time wen u wnt a particular profile to change and it will do so automaticaly.
This is avlbl on feature pck2 phones.. n78 is the first Nseries ph. to have this
