this is not cracked or hacked but a beta for the n95 i stumbled across
please download it and install to phone memory
it worked via the wifi connection at home iam yet to try it with 3g connection its only a beta till the real version is released but it works quite well 😊
hope you enjoy 😊
http://rapidshare.com/files/145773737/BBC_IPlayer_0.3.jar
A jar file?
Does that mean that it's just playing a low quality feed? 😞
Edit:
Ah yes: it just opens up the browser at the iPlayer mobile page, so you get the basic 3gp video clips - you can do that with a bookmark in the browser, as it says: http://bbc.co.uk/mobile/iplayer/index.html
try it and see mate quality wasnt to bad when i tested it , its only a beta untill the other one comes out in early october , just alot of people wanted it so i uploaded it for them
basically this app links you to the bbc channel programme so it dosent store the programmes or anything it just gives you fast access to them via a app link on your n95
it dosent seem to work with 3g it says programmes must be watched through wifi connection guessing this is to keep peoples data charges down , can you imagine streaming an hour long epiosde of top gear to your phone via 3g , surely it would use nearly all your fair usage policy ie o2s 200mb allowance or even vodas 500mb
shame though would have been great to have the choice as 3g is fast enough to stream
lucky everywhere is getting wifi like pubs hotels etc so it will still be a handy application to have
iplayer worked perfectly for me 2 days ago but now I am unable to get to the mobile version via bbc.co.uk/mobile/iplayer/index.html and so cannot stream any programmes. I can still play the few I saved. any ideas?
this happened with the i phone beta. you'll probably find this happens occasionally, but will be back to normal in a short while
