Since receiving my 9210 back with 4.13 on it, I see a "Backupserver Thread" app(?) in my Task Manager - System Window.
This little baby is taking up a very precious 252k (I can't believe in 2002 that I would be worried about a measly 252k but there you go!) and it has never been there before. Ever.
Does anyone know why it would be "hanging" around and what I need to do to ensure it doesn't sit there in the future (assuming it is not system critical).
I just don't like the look of it and I need to be IN CONTROL!
That's the best 'app' Nokia made for the Nokia 9210. It automatically closes all your 'programs' if it needs more memory. But only the ones under the blue buttons (Extra's, Desk, Calendar, etc.).
If you only have the telephone application open it dissappears. And reappears as soon as you press one of the blue buttons.
So enjoy your 'loss' of 252K because it gives you a more stable 9210 and less memory problems.
Thank you for showing me the light.
This will be one little prog that I won't be repeatedly "ending".
Cheers
