Hello..i Have An Nokia N95-1...rm159 ...display Is Only Working The Backlit..no Information On Display!...you Can Call Out Emergency Nr.and Use The Player! Battery Ok!...camera...main 5mpix Dont Work! E.g. No Display At All! Please Advise Me! I Have A Lot Of Contacts Stored On The Phone! Alternative Can I Via U-usb Download Telephone List!?.....thank You For All Help ! 55!...holger
nokia n95 display no info
Do you have a TV-Out cable? if so plug it into a TV and plug it in and press the left softkey ( I think )
If you get a picture then its possibly a dodgy screen or the ribbon cable has come loose.
Can you back up with the usb cable? And if you have Microsoft Outlook you can back up all contacts to the contacts folder and view them there. And if you get a new phone you can transfer the contacts over.
