Slider of the N95 8GB
5 replies · 2,892 views · Started 18 September 2008
Hi, i had to register to express my problem and find out if this its normal or what, because is very annoying.
My n95 8gb at the close position, if i put the finger on the screen and move it up and down (talking about X axis (not Y or Z axis), same movement that you do when you try to reveal keyboard) it moves about a 1mm and sound a "click", its very shaky at this position.
Does this is normal, comes with this problem?
Thanks and sorry for my english, is far to be perfect.
This is normal - my N95 8GB did that as well. Over a period of time it got looser and in the open position it used to wobble. There are several threads about this if you do a search.
Yep, same here. Altho it's not really 1mm, it's less than that, but yes - there is some play. It really started only about two weeks after I bought it, and DIDN'T get worse over the time. I have the phone about 3 months. And it's "made in Finland", if that matters...
Thanks for the answer.
Yea its kinda annoying when the slider goes up or down and you hear the click... makes the phone worth less than 100$... i'll try nokia care, if not, i'll dissassemble and see what i can do
igoticecream wrote:Thanks for the answer.
[SIZE="5"]i have the same problem and tried to disassemble it to fix it ...
but couldn't i guess there is no solution for that. !!
[/SIZE]
