Just got my i8510 (great so far), and have downloaded the Route66 map to try out, but having used Tomtom for years I like the postcode navigation system.
Is this available on Route66 or any other navigation system?
TIA
Grahame
TIA
Grahame
Yes the Route66 app on this phone does have postcode search facility - just go into the search option, then into the address heading and type in your postcode. but be sure to leave a space between segments, ie. EC1A 7AJ as it doesn't recognise the postcode otherwise.:icon14:
Been trying Route66 and it seems OK but no POI's (which is a pain), the only other GPS program which works seems to be Copilot Live 7.
Has anyone used this and can it use POI's?
Also of the 2 (Route66 and Copilot) any opinions on which is the better.
Grahame
Free apps like Amaze might work, but they will be crap in comparison to Route66 or CoPilot. Its a shame TomTom, Sygic, Garmin etc dont work yet, but Ive got a 15 Day trial on Route66 and a "questionable" copy of CoPilot
