nokia maps 2.0 navigation questions
0 replies · 1,794 views · Started 21 September 2008
hi,
just a quick question regarding the nokia maps 2.0
when you are actually navigating from one place to another, is it possible to roam around to see where you are going by moving the map around and return to your position by pressing '0'? It worked in the older versions but when you try to do the same thing with this version, the view changes form 2D to 3D.
Any help would be massively appreciated.
Thanks, Adrian
