Operator logo
5 replies · 1,976 views · Started 12 February 2003
Hi, when I set oplogo, it shows for a while and than the name of the operator appears and stays without showing the set op logo?
can some explain why I cannot set op logo?!
10x.
Miro
The opearator logo is on your sim, and it replaces the logo you set.
Nothing can be done about that. I have the same problem. 😞
Have heard rumours that on fw v.4.39 the logo always works.
A search would have been helpful again. 😉
got a question. what app. are you guys using to set the operator logo? i've tried with eFile manager, but doent work for me. also wanna ask, if there's another way to activate more color palettes, cause the extender does not work for me, ... v.4.39! 😮(
hope you can help me.
bata
