i got this pocket nancy application & found that we can use it till 28 feb after which need registration.Inside the registration,it ask for the phone number & I key mine in.After that,i received a strange numer with some alphabets on it & i have found that the sms indication on the top right hand corner just below the battery indicator is always ON.Anyone had that kinda trouble before?Any solutions?Thanks!
pocket nancy trouble
HI!...
that is not a problem...
Go to Messanging App and go to OUTBOX ...
There you have an outgoing SMS that can't send because you are
in a wrong plase or operator to make the registration...
you can Delete that message on your OUTBOX in order to delete the
outgoing SMS indicator below the BAT indicator.
PocketNancy just create that messange to try to register... that's all..
i supose that you have to contact in other way to reagister the software.
cya!
Using an SMS message to register some software...
Remember the debate this sparked last time?
Glad to see some developers are willing to do what needs to be done to protect their software! 😃
