I had mario deluxe in it & try to get another game-> .gbc files into my mobile by Infrared but the other game could not be open through zipman.Does it mean that i have to delete mario deluxe in order to change into another game?any having the same trouble?
Goboy question
Have you installed the GoBoy ZipMan plug in?
You can have more than one game on your phone at a time.
i have the goboy plugnin but the just could not get more than one game.I have tried using many type of games with either .gb & .gbc but just cannot.please help!thank you
I HAD THE SAME PROBLEM...TRY THIS......INSTEAD OF TRYING TO OPEN THE GAME FROM THE INBOX DO THE FOLLOWING.....OPEN THE ZIPPED FILE FROM THE INBOX WHICH WILL TAKE YOU TO ZIPMAN THEN OPEN THE SAME FILE WHICH WILL TAKE YOU TO GOBOY, BUT, INSTEAD OF SELECTING PLAY, GO BACK AND EXIT ALL APPLICATIONS.....THEN SELECT THE GOBOY APPLICATION AND THE GAME WILL BE ALREADY SELECTED STILL...THEN TRY PLAYING IT....IT WORKS FOR ME.....SOMETIMES IT SAYS MEMORY FULL BUT IF I DO WHAT IVE JUST EXPLAINED IT WORKS....HOPE IT DOES 4 U
sorry about shouting. hahahah. forgot the caps was on
