Debranding a Nokia 6220 classic - Need Product Code
5 replies · 22,775 views · Started 23 September 2008
Anyone know the product codes for the new Nokia 6220 classic.
I got one off EBay but it has 3 (three) s/w on it.
I need to know the Generic product code so I can get all the three rubbish off it. I have unlocked the phone already.
Cant find it anywhere on google.
Thanks!
The Product code for your Nokia Phone can be forund on the label under the battery in the back of your phone. It's a 7 digit code and usually just below the IMEI number.
itisyeah wrote:I brought it into my local phone shop, they had to send it way, it took 3 weeks to get done and cost me 40 euro.
I have debranded it now using nemisis and nokia software updater.
good day bro. how did you debrand your 6220. do you use local mode (nemesis)?
tnx
itisyeah wrote:Hi,
Thanks!
Here you go [0549325] Euro 1 code, this will remove Three and also change networks to options: GSM, UMTS or Dual
