Debranding question
8 replies · 3,251 views · Started 25 September 2008
Hi guys,
I'm trying to debrand my N95 8GB which is now 0557135 (Vodafone UK). I would like to have the EURO1. I followed the thread how to but i didn't work.
When I click read in NSS it shows 0557135, I change it to EURO1, tick enable and pres Write. It says done down the bottom, but when I then press read again to check it there is 0557..... again.
What I'm doing wrong?
Thx
baliator wrote:Hi guys,
What version of NSS are you using? Did you also install the GSM-Magic app?
you dont need GSM magic for all versions of NSS do you... I successfully manage with the same version to upgrade a t-mob recently without...
when you start NSS, you go to phone info, then scan. Then 'enable' the product code text field and write that??
What do I have to choose during installation of NSS when it asks about services.
Choices:
Virtual USB
F1 USB
Nemesis USB Multi-flashing
Diamond protection service
Prodigy LPT device
thx
i debranded my phone yesterday.best thing i ever done 😊 bet your typing in EURO1 like i was lol.. type in the 7 digit code hope this helps
Ok, lets make a complete fool of myself, yes I was typing EURO1 instead of a code. I'll do 20 push ups as a punishment 😃.
ha ha dont worry m8 i was typing in euro1 yesterday lol .. untill i tried the code then it worked 1st time lol😉
baliator wrote:What do I have to choose during installation of NSS when it asks about services.
Choices:
Virtual USB
F1 USB
Prodigy LPT device
thx
The top one, Virtual USB (assuming you don't have a genuine Phoenix dongle)
