As I have e66 I only use the slider to un/lock it and the message 'keypad unlocked' really annoys me. Was wondering if there's any way to get rid of it...
if you see http://nokia-e66-software.epocware.com/Handy_Keylock.html [http://rs337.rapidshare.com/files/105594470/Handy_Keylock.rar] it says...
"Smartphone keys will be locked automatically at slider closing (without confirmation message)."
...which I might have misunderstood - I thought this will get the useless message off the phone - but nah, it doesn't work as I wanted. All they probably meant by this was that you don't need to confirm locking upon closing the slider.
So checking depelopers forums etc and see what i found...
http://wiki.forum.nokia.com/index.php/CS000932_-_Enabling_and_disabling_keypad_lock
... option 3 says "Enabling the key lock without showing a notification"
Any of you have any clue which utility has this implemented [was googling like crazy but got no luck] or is there someone skillful enough to use that simple piece of code?
Maybe I explained the whole stuff a bit weird but hope you got my thought :] Any comments appreciated!
