File Manager v4.13 for 9210 needed
13 replies · 7,560 views · Started 12 February 2003
I have upgraded my 9210 firmware and now I'm looking for the individual sis file for File Manager (firmware 4.13).
I have All_nokia_data.sis but I don't need all the programs there so I'd rather install them separately. My Nokia CD has File Manager for older firmware.
To clarify; this is European 4.13 firmware (english). Is there anyone who could help me get the individual sis file, please?
Thanks!
[quote="pakkato1"]You find individual sis files here http://www.nokia.com/nokia/0,5184,1896,00.html[/quote]
Unfortunately no I don't. File Manager is *not* there individually.
[quote="TheSpecialBoy"]After you format your 9210 you will be able to see File Manager.
Just reformat and you will see it preinstalled.[/quote]
Unfortunately, this is not the case either.. It's not there after formatting. It's missing but I guess no-one has the individual file so I'll have to go with the all_nokia_etc.. file.. 😞
Thanks anyway.
I had that similar problem I searched the web for that individual file but with no luck. You really have to install all_data to get it back. It worked for me. 😃
[quote="apcaw"]I had that similar problem I searched the web for that individual file but with no luck. You really have to install all_data to get it back. It worked for me. 😃[/quote]
Yup, that's what I ended up doing.
It's a bummer though since File Manager is included individually on the Nokia CD (but mine is now for the older firmware). And All_Nokia_blahblah.sis file includes lot of stuff I could do without 😊.
For all of you ... if you need individual SIS files (4.13) write an email, and tell what you need. And, it`s right. The File Manager IS NOT on Nokia site, and i think this is the only one that is missing. :black:
Just out of curiosity: if File Manager is the only individual sis-file missing, why is that? Is it because
a) Nokia just forgot to include it?
b) Nokia thinks that it is such a crappy app that everyone will replace it with something else anyway?
c) Nokia thinks it is such a great app that excluding it will make everyone install the All_Nokia *.sis and that's what they want?
Any ideas? 😮
i think Nokia take out this SIS file, becouse, in some casese can produce unwanted results when you install this. I have some of this problem with my boss Communicator. Several times i try, and finnaly work... Could be that...
