Hi
Anyone know where i can download the bbc i player separately for my Nokia N96 Thanks
BBC I Player
I think the BBC services are only available in the UK (as the UK taxpayer pays for them), so you have to reside in the UK to use the iPlayer.
Did you buy your N96 elsewhere?
Chances are you can find the iPlayer in Download! if you connect with a UK SIM card..
ninetysix wrote:I think the BBC services are only available in the UK (as the UK taxpayer pays for them), so you have to reside in the UK to use the iPlayer.Did you buy your N96 elsewhere?
I'm in the uk, and I have a vodafone branded N96, I can't see where to download iplayer either.
Same i got mine in the Vodafone store and is branded, however it come without the app and its not on BBC's website where it was supposed to be on the 1st October. (today)
According to the BBC it should be available to download starting from today but I couldn�t see anything. I wouldn�t mind trying it on my Nokia N95.
BBC article - http://news.bbc.co.uk/1/hi/technology/7603606.stm
Yup thats where I saw it, not very good if they have delayed it or something. N96 hasnt turned out to be what I thought so far. Might have to get something else.. I think if you buy it from Vodafone you get 14 days, thing is theres notihng else out yet I want, i8510, not on vodafone though. C905 is coming out, but back to bog standard software..
oxfordmark wrote:Go to http://www.bbc.co.uk/mobile/iplayer
Magic, downloaded, installed works a really well
azzy wrote:Hi
I installed the BBC iPlayer from a link right here on www.allaboutsymbian.com. Initial start-up is a little laborious, but once the app is fired up it runs beautifully. I'm connecting over WAN, and I am a little disappointed with the compression ratio, especially after watching the pre-loaded videos from Nokia and the BBC which were stored on the internal drive.
However, lovin' it so far.
Has anyone found a way to make it work from outside the UK ? 😉
It seems that the content is blocked when you are not in the UK.
Can we download programms or stream over 3g yet as mentioned on bbc website or is it just of wifi?
