Hello , i have just seen there is an update for the n95 but you are able to get in on the n95-2 8gb ,
i would just like to check which product code , becuase i tried euro1 and it said it was at the latest update so what product code should i go for please.
also i have no idea why this has happened, but i am unable to open the application folder and ngage so , i even removed n gage and tried to put back nothing happened.
i just can't get in the application folder it's like this , you go to the menu screen , i select applications nothing happens but where on the bottom right screen it sais back , when on the menu screen it sais exit, also i can go anywhere on the folder as it still show's im in the menu but when i press contacts for example i would get the alarm clock open.
