Garminxt + gatso
1 replies · 2,162 views · Started 28 September 2008
Had Garmin workin on my n95 for a while and after using it in southern ireland was very impressed.However I now have a long drive on a weekly basis from northwest uk to the east coast so last week i decided not to use my navman in car set up and try the n95.As regards the route everthing was a1 but was a little peeved that there was no camera warnings.I have ver4.10.60 and have a folder in poi with a speedcamera.gpi file in there along with another file called poi.gpi so can anyone explain how i would get the camera alerts to work.thnx
I hazzard a guess that the speedcamera.gpi was not installed correctly because its should install under name POI.GPI. I think that your POI.GPI just has general points of interest.
Check in settings / proximity points and see if either custom POI sets or garmin safety cameras is enabled. Try one then the other and see if one works.Thats best place to start. If neither dont work take both files out and re-run POI installer with your safety camera .csv files.
Crispy
PS. if anyone has got custom voice for their speedcam warnings working, please give me a shout. Its buggin the ..... out of me.
