I have .cdb file qith contacts an I have no 9210. Does any program exists to convert this file to any "normal" file format, ie. csv, dbf, xls, ...
Thanks for any suggestions.
What format do you want it?
If there's nothing too private on there, you could probably send it to someone who has a 9210 and they could convert it for you into something more useful.
If you want me to help, drop me an e-mail.
Further to my previous comments, Smallbase <I>almost</I> imports the contacts database (now that it support EPOC database format).
I say <I>almost</I> because while it recognises various tables that are in the file, it falls over during import.
My guess is that this is because it can't handle fields with embedded objects such as pictures.
Try to install Nokia9210 Emulator on your PC.
As of version4, SmallBase does import a contacts database!
Coo-el!
