Quick easy question
3 replies · 2,948 views · Started 29 September 2008
Hello,
My N95 LCD screen is broken (but colourful) after lying on it whilst watching the Grand Prix yesterday. It's insured, so not too much of a tragedy, but now I'm at work and would like it to be on silent. Can anyone tell me what are the key presses to select the silent profile??
J12321 wrote:Hello,
There are several ways:-
1. Try pressing and holding the # button for 1/2 seconds. On some models this toggles between General and Silent Profiles.
2. Qouiclly press the Power button on top of the phone and press the down Nav key twice folloed by the left Blue key. This will take you to Silent on the Menu and the Blue left key is Accept.
Hope it helps. Good luck with the screen.
yeah, the # key is normally the way to go, but rather than it going to silient... it goes to profile #2/ So long as you havent changed your profiles, you should get silent activated!
If youve changed your silent profile tho... to REALLY MOFO LOUD, you might want to take the second route ian describes! 😉
kontraband wrote:If youve changed your silent profile tho... to REALLY MOFO LOUD, you might want to take the second route ian describes! 😉
But not literally cos if you've changed your silent profile then you wouldn't press the down key twice 😉
