P800 in Kuwait. need MMS & GPRS settings
10 replies · 3,986 views · Started 12 February 2003
Try this it should work for free MMS if you have wap or GPRS account
http://my-symbian.com/forum/viewtopic.php?t=1696&highlight=
Foruksa
that NowMMS workaround sounds interesting, but since there is GPRS & MMS service on MTC Kuwait i'd like to use that.
BTW, the auto settings that are sent by MTC doesn't work :x
i had a friend of mine take it into the MTC engineers & they managed to get it to work.
but they had to do a Master Reset before finding out that my SIM is too old & they replaced it with the newer SC-21 type. that got MMS & GPRS working fine.
all was great till i did a restore. Now i'm back to square one.... help
i Recieve mail threw NowMMS server ... i got a p800 phone
i am saudi i live in Riyadh .... we got WAP service @ STC .... i have enabled it and now using it ... my problem is when i recieve a notification for MMS .. it auto dials the WAP connection and download the header or the whole msg as u request in the MMS setup .... but while i was sleeping .. i had a MMS .... it has dialed the Connection and downloaded the MMS from the Server and Kept the Connection Connected with out disconnecting ... it has charged me for connection time .... how can i set Auto Disable ... do u have my same problem ... i tried eveything in the setup "promot Connection dialog TICKED " what else can stope the Auto Connect ... or making Auto Disconnect enabled after downloading the Messege
please help me
Do we have to Contact Sybain to Add A Auto Dialup or Auto Disconnect in the Update vesion .. ??
[quote="nim_181"]i Recieve mail threw NowMMS server ... i got a p800 phone
please help me
Do we have to Contact Sybain to Add A Auto Dialup or Auto Disconnect in the Update vesion .. ??[/quote]
hi! i also live in riyadh--do u mind sharing your mms settings?
thanks!
For MMS service Please follow the above link
to set your WAP on the P800 in Saudi Arabia check this link
http://my-symbian.com/forum/viewtopic.php?t=2298
Of course you should subscribe in WAP service by calling 902 which will cost you SR.20 per month and SR.0.50 per minute.
Foruksa
about the Auto Disconnect of the Dial up WAP connection ....
does it happens to you foruksa ??
have u ever got an MMS message ... and u were away ... and it has been downloaded .... then the WAP connection was still running and connected .... tell me about ur states
hi EchoFox23157 can you please tell me where can i get p800 in kuwait , coz p800 is very difficult to find in kuwait,any particular shop in mind where for sure i can get this p800.
Hi all
i have a pocket pc, i'm thinking on change it with a p800, but i want to know if it can support arabic.
one more question: whats different bitween symbian OS and pocket pc??
