Hi all,
I have just tried to accsess my dictionary and get the following message: Unable to run PowerDic. Dictionary databases should be installed ( #09)
What could the problem be. Any suggestions? If the database is infact not installed, is it possible to reinstall the original application from somewhere.
I8510 Innov8 16Gb
198862 wrote:Hi all,I have just tried to accsess my dictionary and get the following message: Unable to run PowerDic. Dictionary databases should be installed ( #09)
I8510 Innov8 16Gb
Try installing Y-Browser and looking around in Z:\system\install\ maybe the install file is there.
Thanks for the reply.
I did as you said, but I cannot find any application that looks like the Power dictionary. Any other suggestions? What would the .sis be called?
I8510 Innov8 16Gb
This happens when you are connected via mass storage mode to your PC. Disconnect or change to PC studio mode and you should have no problems...
Thanks for the reply. Unfortunately, I still have the same problem. I have changed the phone to PC Studio, but get the following message when trying to accsess the dictionary:" Unable to run Powerdic. Dictionary databases should be installed.(#09)"
Can you or anyone else suggest another solution?
Thanks again.
I get the same message about the dictionary. I was stupid enough to delete the files because I thought it was through an application I downloaded and not the dictionary. Now I don't have it and the dictionary won't load!
However, I know you can download it again through: http://www.diotek.co.kr/eng/download/download_powerdic_s60_trial.asp
But the signup isn't working and you may have to pay. Can anyone copy the files by any chance?
Hi all,
Sorry for my bad english, I have the same problem, I deleted files by mistake, please someone can copy the necessary files?
Thanks.
anyone...please? I still need them 😞
hi all, i idioticoally deleted all my powerdic files as it seems some of u have. I see no luck so far. I was wondering if anyone knew how, if i could, use my partners powerdic files and copy them to my phone using the computer as we have the same phone. Only had the thing 2 weeks still trying to work it all out. Thanks.
Bongoi8510 wrote:hi all, i idioticoally deleted all my powerdic files as it seems some of u have. I see no luck so far. I was wondering if anyone knew how, if i could, use my partners powerdic files and copy them to my phone using the computer as we have the same phone. Only had the thing 2 weeks still trying to work it all out. Thanks.
i did it. I opened the phones in mass storage mode copied the files from one to the other, then turned my phone off/on and hey presto instant dictionary.
Hi Bongoi8510,
I did exactly what you did a couple of months ago. Infact I was the first person to post and try and seek help on the forum, but no luck. I don't have access to another phone. I was wondering whether you would be able to send me the neccesary files via email. I've really tried everything and even went as far as purchasing the dictionary from Diotek directly, but are unable to download it from there site and haven't been able to get an answer from Diotek in english, evrything is in Korean.
I would really appreciate it.
Regards,
Ken
[email][email protected][/email]
198862 wrote:Hi Bongoi8510,I did exactly what you did a couple of months ago. Infact I was the first person to post and try and seek help on the forum, but no luck. I don't have access to another phone. I was wondering whether you would be able to send me the neccesary files via email. I've really tried everything and even went as far as purchasing the dictionary from Diotek directly, but are unable to download it from there site and haven't been able to get an answer from Diotek in english, evrything is in Korean.
Regards,
Ken
sure i can i have the files on my lap top at home, i am going away for christmas and will email you as soon as i can probably about 2 weeks. At the moment im stuck using wlan on my phone. When i send the files save them in a safe place on your computer just in case. Ha!
Bongoi8510,
I cannot thank you enough. I can't wait to get this phone sorted out now. Looking forward to hearing from you again.
Ken
Hi Bongoi8510,
Any chance of sending me those files that I managed to delete. Will appreciate the help tremendously.
Thanks a mill,
Ken
