FM Transmitter on N78
7 replies · 11,584 views · Started 30 September 2008
Just in case you don't know already� 😊
You can now use your FM transmitter on N78. It allows u to transmit music from the device to the radio over a short distance. There isn�t any wires conecting the two together and it is simple to set up and use. You can tune in your car radio to the frequency set on the N78 and can easily play the music playlist on ur phone, which will then transmit the same to the car radio system and boom through the speakers. Takes away the hassle of creating CD�s for fav. numbers.
Here�s a short demo � http://in.youtube.com/watch?v=NjsUNZ1BdWQ
...but it does not work for playing streaming audio from say, the n78's inbuilt internet radio app. Pity!
I bought my n79 on ebay, and it has come without the FM transmitter application, can anyone point me in the direction of where i can find it?
thanks.
In some regions/countries the FM transmitter has been removed/disabled (local legistlation prohibiting such devices/functionality). In other words, on a N79 (its firmware version) intended for such a region/country, it isn't there to find, I'm afraid.
N/A wrote:In some regions/countries the FM transmitter has been removed/disabled (local legistlation prohibiting such devices/functionality). In other words, on a N79 (its firmware version) intended for such a region/country, it isn't there to find, I'm afraid.
is there a way i can download and install the FM transmitter app
or can i flash the firmware and put on one which has the FM transmitter. (i'm in the UK by the way, so FM transmission i legal, i believe.)
the method in the link above won't work because Nemesis Service Suite doesn't recognize the N79 yet 😞
