Just to let people know about the N78. I upgraded to one of these from a Nokia E51.
First of all the build quality is very low - its very cheap 'creaky' plastic.
Secondly the power charge point is on the left side of the phone - so if you are taking a call in your right hand and charging - you end up having a wire stuck in front of your face for the call.
Thirdly, the buttons on the edges dont work all the time - (menu key, call start, left selection key, right selection key, call end, C key). Sometimes you will press them and nothing will happen. Especially annoying if your alarm is going off and you press the left selection key which is stop and nothing happens lol.
The smearing and fingerprints that appear on the phone are TERRIBLE. Its a finger print magnet.
Also (this is just a critism of N series60 FP2) you still cant configure the standy screen like you can on the E series phones. In fact they have even added another bar on the front screen which wastes space and messes it up called the ovi sharing bar which constantly displays on the front screen with no way to remove it). [this is using the standard horizontal standby system].
Also, the screen completely switches off when in standy, you dont even get the dim time/date screensaver (guess this was an attempt at saving battery life), although the battery only lasts about half the time that it does on the E51 (about 2.5 days in comparison to 6 days on the E51).
Thanks, and I hope some of these comments help save some of you!
(Im now back using my E51 and I will have to wait another year before my next upgrade)
