Singapore I8510/Innov8 doesn't come with Roadsync
6 replies · 3,693 views · Started 02 October 2008
Hi All
Was just curious to see is anyone else having the same problem?
I rercently bought the phone in Singapore and just noticed it didnt come with Roadsync, yet the rest of the world does.
How am I suppose to get push email now?
Does it mean I will have to fork out some more money?
Does your country come with Roadsync on I8510/Innov8?
taki1986 wrote:Hi All
Hi there taki1986,
I had the same problem as you, i thought the phone came with a pushmail app but i couldnt find it. What i did was install Y-Browser and looked around on the phone and accidently found the Roadsync install file hidden on the phone.
When you have installed Y-Browser go to Z:\System\Install\. The Roadsync.sis file will be there for you to install 😉 Goodluck! Oh and be sure you copy the sis file to your E: drive and then make a backup of it on your computer. They might remove it when a firmware update comes out :P
I have Roadsync running fine. After installation it will ask to register, just click ok or yes and the app will register without problems! 😃
Hi
Thanks for the help.
Unfortunately i cannot find the sis file. After installing Y broswer I went into Z:\System\Install\ but there was no roadsync.sis file.
Is it possible for you to copy it to your computer then email me as an attachment?
Thanks.
If it's not there then i dont know dude. Im not gonna send you my .sis file as i don't know if it's registered to my IMEI nr. Sorry dude.
Mine doesn't have Route66 either.
Is there somewhere I can download it without paying for it?
PM if needed.
