Hi there,
anyone knowing how to overcome double entries in my E71 after syncing with outlook? Don't want to go through those many entires manually. Any software which can do the trick?
Thanks for any advice ..
Bernhard
Hi there,
Bernhard
This usually happens to me after syncing with two different PCs (work and less frequently home). Have yet to find a sensible solution!
You're best doing the removal on the PC
http://office.microsoft.com/en-us/outlook/HA011424371033.aspx
Google "duplicate appointment remover"
for stuff like this (never used it, but it's an example)
http://www.anti-dupe.com/purchase/purchase.aspx
