AlertMe 1.5 Beta:protects your phone from thiefs
0 replies · 3,523 views · Started 03 October 2008
Alert Me is an antitheft application that uses your phone's accelerometer to detect sudden movement and triggers a very loud audible alarm. Latest python, scriptshell and megapymodulepack required.
The application is confirmed to be working by some people ( hence the screenshots) while some people have reported negatively. Try your luck.
Bugs Fixed:
Exit button working fine now.
And i added a setting for reaction to start button.you know pressing start button causing movement and that is making app. alarm
you can set it from "Set Reaction To Start" menu
Background is resized to fit screen.
it can give an error like "updating fail" if the older version of alertme is installed on ur phone.
Download
Developer's WebSite
