Phone: Nokia n95-3
I have installed the s60 TomeRaider 3 beta that I downloaded from the TomeRaider website but how do I go about registering it? It is aparently free since it is in beta but I cannot get it to pick up my tr3 files.
1. Do I have to register the software to use it? Is it free to do so? How do I do so?
2. Can it work with the large wikipedia (3.4gb) tr3 file on an 8gb microSDHC card? If yes, do I have to put the file in a certain folder to get it picked up by the software?
Thanks for any help/advice,
Noel
I have the same problem with a Nokia N96.
Is there nobody who solved the problem???
Please help us!
Hi once again,
The mass memory of the Nokia ist formatted in fat32. Is it necessary / possible to reformat it into ntfs to handle with files > 4gb?
Thanks for you answer!
Has anyone managed to get Tomeraider S60 working? I have managed to install it, but it cannot find any of my tr files. Perhaps these should be placed in a special folder, but I have been unable to find out what this should be.
Tomeraider seemed to go open source about a year ago, but I can't find anything on any new developments other than the iPhone version. Anyone know anything.
Best wishes,
Martin
