Please post your settings for MMS/GPRS in Kuwait (MTC)
6 replies · 2,957 views · Started 13 February 2003
Hello My Friend . what i need to tell you that i think i saw the Settings in the NOWMMS operator Settings Link ..... try it out ... u will find what you need ...
just been to:
http://www.nowmms.com/Operator%20Settings.htm
Kuwait was not listed in the table....
since MTC provides MMS & GPRS services, i prefer not to use nowMMS.
We dont have MMS nor GPRS service here in STC ..... but we do have wap .... and that site provides u free MMS service .... it's working well ... why do u need to charge ur slef More on it .... what makes you say that you are not going to use it ...
u have discoverd it .... it's free ... is WAP connection more expensive than using GPRS and Sending MMS throw it .... it depends on ur DATA size .... so what ever happens ... a Free MMS service wont charge you for sending DATA with a bigger Size ... and what it need from you is Just WAP connection to log on ..and down load ...!!!
tell me what's in ur head ?
nim_181:
WAP costs KD0.005/min
while GPRS+MMS costs KD9.500/month with 24HRS open connection.
so its much more cheaper to use GPRS/MMS
Mishary:
Thier OTA (Over The Air) Autosettings don't work! i've tried it several times & i simply doesn't work...
have you tried it with your P800? is it working?
