Fits perfectly flush with a little sanding. 😊
My backup phone.
http://img217.imageshack.us/my.php?image=dsc00112bq8.jpg
http://img134.imageshack.us/my.php?image=dsc00104yx4.jpg
My backup phone.
Cool! :icon14:
I love DIY solutions😊
What's the difference in standby time?
As a matter of interest, did you file it on both sides and how much did you file?
Battery life is pretty good, probably at the same levels as the n95 8GB maybe a little more. Well if we go by the 25%+ extra in capacity then it should last about that much longer.
I removed the top half of the gray tape and hologram then filed a little off the top. I also filed down the inner side of the battery cover. I could file the battery cover more but no need since the fit is good.
EDIT: BTW this is a generic housing and not the original.
