problem removing "all nokia 9210i data" access den
5 replies · 3,375 views · Started 13 February 2003
how do i supposedly to remove this all data thing
and i have had try ctrl-shift-f to format
but i can't go to the format screen
help meeeeee
First of all you have to decide what you need:
Removing installed aplications or
Formatting the Device
Try using format string after reboot, only when you see Shaking Hands Logo.
hahaah
just formated my phone
and i forgot to backup my ringtones hahahah
btw do u hav a ringtone called binary.wav ????
hi...i was removing some apps den i accidentally removed "all 9210i data" although it wasn't complete, it totally deleted the clock, memory viewer, calculator, real player, excel, word, presentation, file manager....now i don't know wat to do cuz i havn't backed up my files yet cuz i just bot it! wer can i get the software so dat i cud retrieve all of the lost data???? please help me!!!!!! [email protected], 639167331681
what kind of lost data? like your calendar or something? or the applications? the sis files? i think your data are lost, but the sis files has a remedy, your phone comes with a cd right? browse the cd and install them to your phone.
