I made my choice!!!
8 replies · 2,477 views · Started 13 February 2003
what is the max resolution? And what is the actual size (inch) compared to a normal screen? (17inch LCD is bigger than a 17inch normal monitor isn't it?)
It results to be almost as big as a 19 inch crt...I believe it's 1.6 inches more if I remember well.
I'll go check to give you exact info's!!!!!!
I'm really happy now!!! 😃
i just bought myself the new Sony Vaio Laptop with a 16.1inch screen... an amazing machine.
Does'nt a 17" moniter give you an actual viewable screen of 16"???
Vaio Rocks !!!
HyPeR
i think its about time that i buy a new monitor. this time i'll make it a point that i'll be buying a TFT screen.
