Have just installed the Mitsumi USB Bluetooth dongle, works fine transfers files both ways, works fine as a bluetooth modem. However can't get PC Suite to recognise the phone via bluetooth and therefore can't sync calender or do complete backup etc. Anyone got any ideas if i need to set up anything first to get it to work? Will I need to reinstall pc suite?, doesn't appear in the nokia connection manager, Help !!!
Mutsumi USB Bluetooth v Nokia PC Suite 7650
It does not work and wil never, unless Mitsumi release other drivers.
If you search the forum, you will find this out.
Sorry
Bob
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=6909&highlight=mitsumi
And please try searching yourself next time. You're the third person this week who's asked for help with this adapter.
Sorry I did try searching, but didn't find anything related, obviously did not do it right
[quote="ratkat"]Sorry I did try searching, but didn't find anything related, obviously did not do it right[/quote]
If you're interested in the full story, try a search for "mitsumi AND bluetooth" in the 7650 forum.
It's a sorry tale though 😞
Better read this thread:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=3075&postdays=0&postorder=asc&start=0
I got my Mitsumi working with PC suite after folowing the instructions in this thread 😃
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=7388
HI!...
check this...
i just answer a similar thing to a newbie 😊
here:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=7993
hope this help you...
cya!
richdjs along with gamold you both are my hero's thanks to you both my Mitsumi Bluetooth works perfectly with PC Suite, thanks very much
