Hi, does anyone know if i do a 7370 reset if the Fifa 08 game will be deleted from the phone? Cheers!
*#7370# query
No, but if it does... before you "baleet" your systeem.
Install Y-Browser and go to the Z:\ directory look for the Fifa installer, here you also can find the Roadsync application.
thanks for the tip, had y-browser from day one! Any idea which folder to look in?
EDIT: Never mind, found it... Thanks!
on second thoughts...I've found thefifa install, but not route66, any ideas? Thanks!
Route66? I have never heard of that this is embded in the phone
ITs called Navigator in the shortcuts, but its effectively Route 66 Mobile v8. Anyone know whether this will stay on the phone doing a factory reset?
