HI!..
Just using Doris Browser ...
After a few seconds of been connected (GPRS) while is rendering and loading pages... suddenly the app is closed.. and appear an "APP ERROR W32 B!" ... first time that i see that 😮
Only using Doris Browser... i use IM+ to see MSN and chat and nothing happen, or using email .. all it's all.. so i think is not the GPRS connection.
I reinstalled the App.. and nothing.. same error :cry:
what can i do?
RE FORMAT? :roll:
any idea?
thanks!
OK!..
i found what it is by my self 😃
it's a BUGG i don't know if is Doris or WildSkinz... or my firmware (3.16)
I don't know if anybody see the same problem...
if you try to navegate with Doris Browser while any skin
is active (ON) with WildSkinz App... simply after a few seconds
the Doris APP it's gone.. totally close with and show an error:
"APP ERROR BROWSER W32 5!"
If you simply turn off the SKIN on WildSkinz option OFF and reboot the phone, you can use Doris normally again... :-?
So.. INCOMPATIBILITY problem?.. between Doris and WildSkins?
or Between WildSkinz and Firware 3.16?..
i don't know...
i like to ear any of you testing this thing to check that out...
thanks anyway..
cya!
I get the same error with 3.12 Its one of the WildSkinz bugs, an other being that you cant open SmartAnswer while wild skins is active. I dont know of any others that it happens with. My IM+ closed down the other day with some kind of error (I didnt catch what it said) but this was a one off and hasnt happened since so I put it down to "just one of those things" rather than a wildskinz conflict.
Stezos
Same problem on my 3650...
Doris works for a few seconds, then error.
Also, MP3GO same problem.
I'm scared of turning SkinZ off again because when I did it yesterday and rebooted, I had a bunch of errors (memory, phone, etc...) during bootup and entering different menus. Also I had lost alpha typing (it would only allow me to enter numerals).
Had to restore all phone memory from MMC.
Oh well....
I just removed WildSkinz (I don't need it that bad). Had to do another restore since the phone went berzerk.
