Dotted circle
4 replies · 2,247 views · Started 08 October 2008
I've bough this phone on 2 october and within 1 day I already have dust under the screen. On the top right corner (I barely touched the phone) with a price tag of €579,00 (which I've fully paid, not sh!t from a provider) I can say it's not some toy phone.
As of today (7 oct) I've swapped the phone for a new one.
Also there is something that does bother me.
When you're doing something and swap back to the menu you'll see a dotted circle.
I know when I open/start a folder/app there will be a rotating ring.
Does that dotted circle rotate?
As i mentioned in another thread the dotted circle means that that application is running in the background, or an app (or many apps) in that folder is running.
I think you don't understand me.
I do know when I open/start a folder/app there will be a rotating ring when it's in use on the background.
My question is does that dotted circle rotate?
For me
When an app is in background it is static
When an app is loading up its spinning (but not dotted circle)
Hello
srw985 is right . And so are you . I think you just both seem to have your wires a bit crossed . When you first open/ start an app , if you look closely for a brief second you will get a small SPINNING circle (that is more like a solid line but with a section which is faded) . If you come out of an app without first exiting (you have to do this from the options screen , left soft key on most apps scroll to the bottom of the list and select exit ) you get what appears to be a STATIONARY circle of small dots . This means the app is still running in the background . This can be checked by clicking options/ show open apps (the top option on the list) . It has been said on other forums that it is best not to have too many (or none if you can) apps running in the background as this tends to use up precious battery power by working the processor of the phone harder.
Hope this helps 😊
