Trying to setup blackberry on my E90 but cannot find the device PIN
Tried the box, under the battery and the blackberry status tab but in here the IMEI is shown but the PIN field is blank
Any suggestions?
I'm on O2 with latest E90 software
Thank you !
Johnny
Hi there!
My provider is just softlauched the blackberry services and i am the party of BB project. So as of today i was going through the E-90 connectivity and for BIS u need IMEI and PIN u can have them if u follow these stpes.
. Got to Menu
. Go to Blackberry folder
. Go in Settings
. then use the nevi. key right u will see 4 tabs but infact there are five tabs
. the fifth tab is where u can get the PIN and IMEI.
Hope it helps!
ADIOS😊
