N95 8GB Problems... HELP!
7 replies · 2,724 views · Started 09 October 2008
Hi Guys,
I have a few queries with my N95 8GB.
I am no longer able to open Mobitubia!?! It states that the certificate has expired. Does anybody know why this might occur? I have tried downloading again but to no avail.
ALSO my Youtube app isn't working either. Connections just seem to time out, where as before it was working fine. Anybody else have this prob?
Thanks in advance, Scott
for youtube check the connection settings in Real Player. They are actually independent from the connection you chose when you open the app
Thanks very much, Youtube now works. However i would prefer to have Mobitubia working or an alternative program... any advice?
not entirely sure, You could try changing the date on your phone to 6-12 months ago before install. Should fool it to think the cert is still valid, then change back when installed.
Other than that, I'd try and find the latest version of it somehwere on the web wit a new certificate
I will give that a try. My Youtube app does not seem to be giving out any sound??? My speakers and headphones are working on my music player though!?!! Sorry for the constant problems
Know ist going to sound like a silly response, but volume buttons are on the rt hand side, and they seem to be opposite (Probably as they are expected to be used in landscape) So down is actually turn the volume up.
Problem solved!!!
Please forgive my stupid self for wating your time... As i am generally at work when surfing on here, my phone is on silent. This is the reason why Youtube will not play any sound.
Thanks m15chief
