N-Gage News Roundup
3 replies · 1,995 views · Started 09 October 2008
Over on All About N-Gage we've had various news items over the past few days, including confirmation from Nokia that game transfers ARE still possible through customer service (despite the misinformed words of a few service reps recently), there's been an updated version of the game Pro Series Golf to fix compatibility problems with the updated N-Gage app (and it also now works on the 5320), and we've had a bit of a nostalgic wallow as it's five years since the original gen N-Gage launched.
In case anyone missed it, as mentioned above, there's an updated version of the N-Gage application available.
You can install it directly onto the phone by launching the N-Gage app, selecting "Options", and then "Check For Updates". This method didn't work before, but it should do now.
Alternatively, you can download the updated app onto your PC and then install it on your phone with PC Suite by going to the Get N-Gage site:
http://www.n-gage.com/ngi/ngage/web/g0/en/get_ngage.html
Or... You can go to n-gage.com or n-gage.mobi with the phone's web browser (over the phone network or WLAN, and download and install it that way, too).
Yup, the exact address for the mobile download page is:
n-gage.mobi/d
Make sure you type it exactly like this, with no "www".
However, if you've already installed N-Gage the easiest way is to do the "Check For Updates" method which effectively takes you to the same page.
