i8510 no show anything when blocked
5 replies · 3,426 views · Started 09 October 2008
1st of all sorry my english .
When i close i8510 it automatically blocks (until here is ok) but few seconds after, lights totally are off and mobile no shows anything (i.e hour date, messages received , lost calls etc.. Is there any way to configure the i8510 to show at screen (when mobile closed) all that info (like any other mobile..)?
Hi there welcome to the forum
I think you mean when the phone is closed , do you ? Not blocked ? This is a problem that has been mentioned before I think . Unfortunately being able to disply the date , time , missed calls and other information you might like to see , is not supported (at the moment) on this phone . Even though the os is licensed from nokia and their phones do so . We are all waiting with baited breath for a firmware update of some discription , in the hope that it will solve some of, if not all of the admittedly minor niggles we seem to have with this phone .
The price we ALL pay for being early adopters of cutting edge technology 🙄 :banghead: :rofl: :argh:
Hope this helps ? Keep in touch with the forum , it's a great place to come for any help or problems you might encounter with your new phone .
Good luck
Yes thank you, u solved my doubt. Its sad to spend xxx € and get this kind of problems. Hope we get a solution soon. Tx again.
Thanks.
it says version software I8510XXHHa
�What version is �a? supposed ?, caused i just have read at forums versions like HH7 HH8 etc..
