Hi i have a Nokia N82 and plan to upgrade my memory from 2GB to an 8GB micro SD. When i get it can i simply copy the contents of the 2GB and paste it to the 8GB using my computer and continue as normal with the 8GB or is this not possible i have several apps installed to the SD to save internal space (the momory hogs) e.g. installed tomtom where map is on the SD, among other things.
2GB to 8GB micro SD what about the installed to card apps?
Hi
Best thing to use is Nokia Suite, Backup.
Backup your phone with the 2gb card in.
Then switch cards.
Then do a restore.
You might to reregister some of the software, but this should work.
