N95 WLAN Issue
3 replies · 2,127 views · Started 11 October 2008
Hi, I have a N95 (The first edition). I have just received it back from a screen repair and my Wireless isn't picking up my router, even when I'm sitting a few cm's from it. It was working fine before it went to get repaired so I was wondering if you could help me solve this issue. I have installed the latest update but it hasn't made a change.
Thanks in advance.
I don't think screen repair has something to do with this issue. The problem is due to the loss of your WLAN setting during updates. Probably you would not have backed up your phone setting.
It is better to feed IP address, default gateway and DNS servers addresses manually. Your reouter booklet would describe its specifications with regards to IP settings. The default gateway, DNS server addresses of the internet provider, of your router and N95 should exactly match. The fourth portion of the IP address on N95 should be fed a few digit high as compared to the router. If you feel any trouble let me have the details of your router and inter provider and I will tell you exactly what to feed.
It wasn't working before I updated it so there would of been no settings to save. Nokia have restored it before they sent it me back so they might not have backed it up. I have entered manually but no hope. Im gettin an error when tryin to get on to the internet which is telling me to check my connection settings.
