Yo people i have put Smartmovie on my n73 but the only problem is its trail...it has about 55mins left on the playback..so could someone please help me
and dont be a fuc**ng a** and say " buy it " not funny
My srial number is 353546028983562
I need the License Key, Thanks.
Hello, i had the same problem with Smartmovie on my N73 too.
Do you have the PC software too??, both PC and phone software are needed to create activation codes to unlock the software!q
If you dont have the PC software,.......
Google for - SmartMovie v3.41 S60v3 SymbianOS9.1 BiNPDA-Vista-modified.sisx (this is to run on your phone)
In order to get an activation code, you need the PC part of the software called, oddly enough, Smartmovie Converter v3.41 - with this and the software on the phone, activation codes can be generated. Then you have the added bonus of the converter too.
Or, if you just want to play DivX movies on your phone without f*****g around, then try,.......
Divx Player 0.90
http://mosh.nokia.com/content/4BFBCC733582EF55E040050A44307FC5
Use the above link if you wish or google for it yourself.
Hope this helps
Regards
Markkyboy
