Hi
Being familia with symbian , I easily found how to set SIP for my I8510 but I don't know how to make a call
I have only two choices , video and cellular but no Toip as I used to see on nokia
Would you please give me a hand on this
Thank you in advance
SIP settings on I8510
I read the manual but still did not find solution
I correctly set my SIP account and I had by the end REGISTRED
When I try to make a SIP call as on the n95 or n82, the optin is missing
Please help !!!!!!!!!!!
Add a SIP phone number to a contact - that seems to enable the option on my phone.
Thanks for reply but no luck
When I select ToIP call, nothing happens
whats use of SIP ? i hav 7710!
stuclark wrote:Add a SIP phone number to a contact - that seems to enable the option on my phone.Where does the option come up for you. I have registered a sip account and added internet calling number, but not sure where to find the option to call.
On some Nokia you have to install an app to get get the SIP Profile up and running, including the i8510 sibling, N95.
I don�t hava an Innov8 myself, but am thinking about bying me one. SIP is a "must have" for me "SIP on Fring is no good, too much lag", so if you still haven�t got it to work, try this link, and tell me if it works.:icon14:
ww.forum.nokia.com/info/sw.nokia.com/id/d476061e-90ca-42e9-b3ea-1a852f3808ec/SIP_VoIP_Settings.html
