Does the Route66 GPS that comes with this phone have turn-by-turn voice intructions?
Is this software free for use forever? If not, is there anyway to get an alternative GPS software that have turn-by-turn for free on this phone?
Oh and, is it possible to listen to music (played by the cellphone) while using the GPS in a car?
Thanks in advance,
Jack
The software is not free to use... you can get a 14 day trial for the maps.. but after that you have to pay to keep turn by turn navigation..
Not aware of any other nav software that works correctly on the I8510 yet
is copilot 7 free and has turn-by-turn?
srw985 have you used Copilot 7? You say it works on the i8510, would you say Copilot or Route66 is better?
Grahame
NO decent GPS routing application, with turn by turn navigation, is free! The entire point is that you PAY to have turn by turn navigation. Google Maps will give you free navigation, but guess what - it's not turn by turn, as that would be a paid-for option! (and there's licensing issues which prevent Google from implementing it)
You're going to have to buy one of the GPS applications to get turn by turn, just as you would have to with any other phone!
my mate has this tomtom application for his nokia that has turn-by-turn and its free....
Jacko3000 wrote:my mate has this tomtom application for his nokia that has turn-by-turn and its free....
I doubt it was free, it may of been pirated.
Piracy and Freeware are different things.
Or it may of been included with the phone in some special offer.
Copilot seems to work fine. Ive not really tested CoPilot or Route66 properly though. Ive only ever used the free trials on either of them.
TomTom is NOT free. Do not post any links to cracked / illegally pirated copies of the software here.
I discovered a free option when i had my n95
http://www.amazegps.com/welcome.php
Amaze gps is free at the moment and its ok, its gets you where you want to go.
go to the samsung / innov8 download section and it works fine on the i8510
I'm using Garmin XT 5.10 in my i8510.
The best GPS application that I used.
